large capicitor vs. small second battery
  • 7
Reidk
Mic boy
242
iowa
I think that I will probably need a second battery or a large capicitor for my system. I'm using a 1500 watt phoenix gold amp for my sub and an 800 watt visonik 4 channel amp for my speakers. My vehicle is a ford ranger and it has a stock 97 amp alternator. I don't know if I should use a second battery or a large capicitor. I really don't want to burn my my alternator up. I'm not sure if i'll need either one. but when i had this system in my honda i had to have a second battery or my system would cut out and the lows didn't hit right. but i also had a 70 amp alternator.
this is the battery i'm intrested in:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=170271127825
no the 70 amp alternator was in the honda. the ranger has a 97 amp alternator. when i had my system in the honda i had to have 2 batteries
Just get a bigger alternator. If you dont have enough alternator to charge the one battery you have now you dont have enough alternator to charge a second battery. Even if you could get a 120 amp alternator and a cap you would be better off.
Im not sure about the rangers, but see if maybe a F150 alt might fit, but idk for sure. I would assume the F150 alt would be about 120-130 amp.
Have you done the Big 3 yet? and do you have a good primary battery?
havn't done the big 3 and didn't do it in my honda either. this system rocked in my honda. but i do have a bigger alternator now and didn't know if i still needed to use 2 batteries. i thought about getting an even bigger alternator for my ranger but they are pretty expensive. so if i can get away with a second battery for cheaper i will. my primary battery is a 875 cca AC delco battery... so yes it's a good primary battery.
well another question is...do i even need the battery or the capicitor?
Go outside while it's dark, turn your stuff up on full blast or as high as you will ever play it. If you are getting bad dimming, you got work to do. I would get the battery over the cap, but something bigger than you showed in that link.
well my old battery was a deep cycle marine battery that worked out really well but it was HUGE which was fine for a trunk. but it is not something i want to put in my truck cab. i figured something small like that kinetic and my big battery under the hood would be enough.
Not really familiar with Stinger batteries, but it looks the size of a Kinetik hc-600.
Try the dimming test suggestion first. I you are dimming, I would put a deep cycle (Red or Yellow top) up front, and do the big 3. What gauge wire is your setup done in?
can't spend that much money on a battery. i'm using 4 guage wire. for the pg 1500 watt amp and 8 guage wire for my visonik amp.
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
You're not going to know until you test with a meter. Typically even carpeting a box as opposed to painting is going to lose a few tenths.
This will be an interesting issue to find out. Subscribed!! Are you running components? Ive had some caps blow in Passive xovers and a little...
966
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
295
  • Locked
COMPLETED Small 4channel amp
I'm really tempted to grab a 4k db 🤔
19
3K
Reidk
Mic boy
Reidk
iowa
BassAddictJ
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
