Mono Amps: Some have A/B some have just A?
  • 4
Ill show pics to show you guys what im talking about.. sacking is on the right page i believe.
ZX 1000.1 see how theres 1 set of wire inputs.. +,-
T1000 +,- "A" +,- "B"
when a mono amp has 2 sets of +/- terminals that just means that they are paralleled internally. i.e. you hookup a dual 4 sub to it, where each coil is wired up to a set of terminals. thats 4 ohm per terminal, then paralleled internally for a 2 ohm load.
Oh, on the outputs. It is just for ease of wiring. Both + and both - are the same internally.
Exactly I figured it was more for coinveince as well, say if i guy wants to run multiple subs?
I see what your saying.. was really lost last time (the only time) we had to hook up my HDC3 which i ordered D2 but ended up with a D1.. we had wires going into all four outputs on my saz 1500.. now what would we have done if there would have been only 1 set of outputs?
  • Locked
324
I get it. I'd never run a tone through at full tilt to test just how much they can take before it goes all willie nelson either 🤣
72
4K
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
Buy the 4 ch and keep the other. Usually on a 5 ch there isnt much of a substage, but there are a couple with a 1k @1ohm ch., but very few. A 5...
boomzabit
boomzabit
Minnesota
boomzabit
    May 18, 2024
    May 18, 2024
