Need Help Wiring sub + amp
Vice
im very new to car audio, this is my first setup and i have a few questions.
i have a soundquebed hds315 D2 woofer (1200watt RMS)
SoundQubed HDS315
And im getting a Kicker Cx1200.1 Amp
Kicker CX1200 1 Car Stereo CX Class D Mono 2400 Watt Subwoofer Amp Sub Amplifier | eBay
My question is: what will i need as far as wiring goes? I've heard i need the "BIG 3" upgrade but im unsure of what kind of wiring, as in what gauge, and also any other wiring for the amp. i know that soundquebed has aa wiring kit for $60 and im unsure if thats too much.
0-Gauge Amplifier Install Kit
Please Help!
for the big 3 do all 1/0 wire.
i use knu ofc .
and if you already have that, wire to 4ohms .
if you did not order that amp, dont.
get a amp that will do 1ohm. and wire sub to 1 ohm.
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Is that 1000w max? Don't expect to be able to bridge a 1000w amp at 2 ohms and get 500w x 2ch. I'm pretty sure you can't with that amp, for...
Vice
Vice
New York (upstate)
big scott
