Need help with new headunit and engine / alternator noise
irokdastar
7
USA
Hello everyone . So I purchased a New android head unit for my car and I did a complete amplifier and speakers . after installing everything I got this hum from the speakers and when I turn on the car I get electronic noise from the engine alternator . I ran the power wire on the opposite side from the rca's . I swapped out the RCA's that came with the amp kit to a Rockford forsgate twisted RCA's and it actually made it worse . I even tried grounding out the rca to the headunit and no luck . When I pull the rca from the amplifier the sound goes away . what can be causing the issue ?
Definitely should go with the ground loop isolators. Did an install at my shop where a customer brought in an android tablet and it did the same thing. We always get down to bare metal but never helped. The ground loop isolators made it way better.
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
482
11
853
858
irokdastar
irokdastar
USA
Beentown
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
