No Sound from Speakers in Bench Tests
  • 2
I am trying to power a car radio from a 2004 Jeep Wrangler using a PC power supply as I do not have an alternate 12 volt supply. I do not have the original female header from the car, so I only have the pins from the radio to work with. After some research I came across the pinout diagram from my poarticular model of radio. I was able to power the display backlight, the lcd screen which shows the clock, radio stations, and other normal HUD displays. I also was able to get the CD player to accept and return CDs. My problem is that when I finally hooked up speakers to the available pins, I was not able to produce sound. I can hear a slight static sound coming from the speakers, which I believe to be proof that the speakers are on. I used multiple different sources of audio like the CD player and the radio with antennae(FM and AM). The speakers are not disfunctional as I tested them with several other appliances and I used other speakers with the same results. I have checked and re-checked my wiring and used multiple different alligator clips to ensure a strong connection. I have some guesses for why I am having this problem which include the PC power supply is not offering enough current to power the entire radio, but I have not been able to find a better source of power. Any responses will be appreciated because I am desperate at this point. Thank you.
It sounds more like an mA issue more so than a voltage issue, as it powers some things but not all. I would look for a power supply similar to what you have and just try to find one rated at a higher mA output. This should be clearly marked on the part that plugs in to your source. Also, I would not continue to test with your current power supply. Underpowering a unit is sometimes just as bad as overpowering one. Hope this helps!
Hertz makes good speaks as does Focal. Often times how "open" a system will sound depends on the vehicle's interior. Big wide dash boards tend...
11
I would pull each speaker and test as well . Check with a DMM and a different HU or? as stated. A 12v battery and an Old HU usually works just fine
11
"I don't have any crossovers" You'll need one to filter out the low frequencies leading to your sub woofer. They'll produce no sound then...
14
Forcebomber
Forcebomber
New Freedom, PA
Forcebomber
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
