Old School Xtant SQ Amps!!
Xtant 1001dx
Xtant 603x
Xtant 1001dx - Number of Channels 1
Watts per Channel - 4 ohm 1x 250
Watts per channel - 2 ohm 1 x 500
Watts per channel - 1 ohm 1 x 1000
Xtant 603x - Number of channels 3
Watts per channel - 4 ohm 2 x 75 + 1 x 150
Watts per channel - 2 ohm 2 x 150 + 1 x 300
Features of 603x:
Fully Regulated PWM Power Supply
Complimentary MOSFET Design
Defeatable Balanced Input
Adjustable Input Sensitivity
24dB/Oct Low Pass, High Pass, Bandpass Crossover
RCA Outputs with 24dB/Oct Crossover
Left & Right Independent Gains
Adjustable Noise Gate
Passive Rear Channels
Xtant 1001dx: $500 obo shipped
Xtant 603x: $400 obo shipped
https://lh5.googleusercontent.com/-oVwN3ZY8Tjo/UpQ8hmWiE9I/AAAAAAAAAF0/dMPO5YqpSbY/w572-h762-no/photo.JPG(List pictures in this section, 1st picture should be your username/date if you have less than 10 positive feedbacks with the i-Trader system or less than 10 references that you have sold to in the past. (These must be listed in your signature, or a link provided to a feedback thread listing these references)).
covers look clean but you'll need a lot more pictures than those for the prices.
also, those could just be the covers with nothing inside since the cover screws are missing. right now there is no proof the amp internals are under the covers.
show the original packaging, manuals, and internal pics showing all screws, crossover cards and modules.
what SIPS do you have?
show pictures of it powered up, and ideally with a scope or DMM on the output channels to show they work.
good luck.
Sorry about that. The 603 has the rm8 module and for sips I think I have everything crossed at 80hz hpf and lpf. There are some around 120 hz but they're on the rear hpf channels which I wasn't using.
Both of the amps work perfectly. I will take a picture later of them powered up. I did research my prices before posting, and there's not too many of these around. I'll take off 100$ from each amp so 400$ shipped for the 1001dx and 300$ shipped for the 603x. Thanks for your help. I'm a noob.
5950990734349800466
5950990735713574354
Also Is there a better way to post pictures on here rather than doing it through Google plus or something?
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
  • Locked
Clearing out storage. $75 + shipping. Located in Carlsbad, CA. Pick up OK. Shipping weight is probably around 13 pounds. Slightly to deep to...
jayroles
jayroles
Stone Mountain, GA
jayroles
    May 12, 2024
Brendon Jenness
    May 11, 2024
