On/off switch for rearview camera
  • 2
the best advice I can gicve is to run it through a relay where either source would close the coil to energize the cam. since it would be using 2 seperate 12v sources 1) the rear tail light, 2) the switch you control. the other thing I can think of is 3 way switching as in a house where you can turn on and off from 2 or more locations.
6
136
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
Disconnect the RCA's or hi-level input to the JBl amp. turn the system on, If the noise continues, it's a ground or noise issue with the amp.If it...
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
824
Thank you all for all the replies, I intend to reply to each and every one individually as I test things out. Here's the latest development that...
13
GreenSmoke
GreenSmoke
Dallas, Texas
tommydh
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
