Performance Teknique amp question
  • 2
superdupernova
my cousin gave me a Performance Teknique ICBM-894 amp and i am lost on adjusting the controls. i have it going into a Performance Teknique ICBM-5912 12" sub. can someone tell me how to adjust the settings on it. Thank You to all that can help. i have attached a picture of the amp sides to show you what it has.
if it is hard to see the picture, it is from left to right- Input Level (Low-High), Remote, LPF (30hz- 500hz), X-Over (LPF-Full-HPF), HPF (50hz- 1khz), Bass EQ (0db- 18db), Level (6v -0.2v)
i have typed the function and put the values in parenthasis ( ).
I just clicked on six separate threads and they went well. Seems to have worked.👍
9
921
Here is a chart that gives you relative cone size. Diameter of speaker*|*Cone area of speaker in square inches 18"*--->*254 15"*--->*192...
15
3K
I have the same issue.... 4dr sedan. Trunk is a bass trap. Ski pass is the only opening to the cabin. Forward firing, pretty well sealed off...
7
Poly fill traps the rear wave of the speaker keeping it from reflecting back and hitting the cone. This reduces 2nd order and 3rd order distortion...
9
superdupernova
superdupernova
Rialto, CA
iceteebone
saints747
    May 7, 2024
saints747
    May 7, 2024
Latest topics
