Performance Teknique amp question
  • 2
superdupernova
my cousin gave me a Performance Teknique ICBM-894 amp and i am lost on adjusting the controls. i have it going into a Performance Teknique ICBM-5912 12" sub. can someone tell me how to adjust the settings on it. Thank You to all that can help. i have attached a picture of the amp sides to show you what it has.
if it is hard to see the picture, it is from left to right- Input Level (Low-High), Remote, LPF (30hz- 500hz), X-Over (LPF-Full-HPF), HPF (50hz- 1khz), Bass EQ (0db- 18db), Level (6v -0.2v)
i have typed the function and put the values in parenthasis ( ).
I just clicked on six separate threads and they went well. Seems to have worked.👍
974
Here is a chart that gives you relative cone size. Diameter of speaker*|*Cone area of speaker in square inches 18"*--->*254 15"*--->*192...
15
I have the same issue.... 4dr sedan. Trunk is a bass trap. Ski pass is the only opening to the cabin. Forward firing, pretty well sealed off...
Poly fill traps the rear wave of the speaker keeping it from reflecting back and hitting the cone. This reduces 2nd order and 3rd order distortion...
superdupernova
superdupernova
Rialto, CA
iceteebone
    May 18, 2024
    May 18, 2024
