Phoenix Gold Octane R Comps
thuggish3000
hey guy's, i was looking at these Comps and i was just wondering how bright this set will be ( havn't ordered yet)
here are the specs:
70/140W (RMS/PEAK) Power
5.25" (130mm) 2-way comp system
Frequency response: 60Hz-24kHz
Sensitivity: 89dB (1W/1M)
Injection molded aluminum plated grained polypropylene cone
Butyl rubber surround
Flat linear roll spider
Pivoting 11mm blue mylar tweeter diaphragm ( don't now how bright)
External 18dB/octave acoustic crossover
I'm just asking if they are bright because i won't order them if they are..
Thanks
yes same guy from Canadiancaraudio.com, but i just need some answer and they where answered ( hopefully that makes sense) but anyway Thanks for the help, how would you rate the ZR's with the Silk dome tweeter?
zrs are a much better set than the octanes... Definately worth checking out.. I still say you should step it up and get the xenons though.
yeah i would get the xenons..i have them...towncar even recommended them to me...the zrs r have a better midbass than the xenons..but the tweets on the xenons are really good for the money
Man, I hope you find what you are searching for. It is deff worth the time spent for something you always want back or wanted period.LOL I was...
817
I just read the other post about this Bass Cube. IMO, it sounds like a signal leveler with adjustable Q. For that you can just use one of the many...
  • Locked
You said, "one of." How many do you have? I'm guessing that you are keeping the best one(s).
5K
thuggish3000
thuggish3000
Ontario, Canada
turnstylez18
    Jun 1, 2024
    May 31, 2024
