Phoenix gold titanium 500.4
  • 4
Jws13
I'm new to this forum, so hopefully I'm going about this right. I came across this item and really don't know much about it other than it's a car audio amplifier. I have no idea if it works or how to determine if it does. I tried to upload some photos but couldn't get that to work. Any info is appreciated... thanks
  • Maximum Power : 500 Watts
  • Low Frequency Response : 20 Hz
  • High Frequency Response : 20000 Hz
  • Number of Channels : 4
  • Built In Crossovers : Yes
  • Channel Separation : Yes
  • RMS Power Range : 75-250 Watts
  • Selectable "Q" Control
  • 75 Watts x 4 (4-ohm)
  • 150 Watts x 4 ( 2-ohm)
  • 250 Watts x 2 (Bridged 2 Ohms)
  • 24dB Continuously Variable Crossover
  • HP/LP Crossover with Aux Out
  • Built-in Fan Controlled Operation
  • Twin "T" Bass EQ Circuitry
  • Low Pass Level ( LPL) Control
  • Load Stability: 1 Ohm Stereo
  • Titanium Finish
  • Dimensions: 16.0 x 10.0 x 2.25 (LxWxH)
Thats a Classic sought after amplifier. You can do a quick test at your car Battery to see if it powers up or not. Poss/+ to Poss/+ and Negative/- to Negative/- and Take a wire and go from either Poss/+ on Amp or Battery to the the remote section. Give it a couple seconds for amp to click to come on.. @ Power LED light on top (Three dots)should Light up Blue , and should at least be ready to test further on the bench or in a vehicle where there is 12v of power and an HU and speakers.
Man, I hope you find what you are searching for. It is deff worth the time spent for something you always want back or wanted period.LOL I was...
590
I just read the other post about this Bass Cube. IMO, it sounds like a signal leveler with adjustable Q. For that you can just use one of the many...
  • Locked
You said, "one of." How many do you have? I'm guessing that you are keeping the best one(s).
5K
Does anyone know how to install the phoenix automotive tesla head unit in a hummer h2 2004? Hey gave no instructions but claim it's plug and play.
Jws13
Jws13
Colorado springs
spokey9
    May 10, 2024
3toneEYZ
    May 10, 2024
