Please help aero port width and length
  • 2
I'm going to use a couple jl w3 12 but the box will be sealed im trying to figure out what length and width of the port can get me lower the amp will be kicker zx 1000.1
Seaed and ported mean 2 different things.
For 2 w3 12's you would aim for around 2.5- 3 cubic feet sealed and 3.5-4 cubic feet ported. It's not as simple as just putting a port in a sealed enclosure.
If your current enclosure is 3.5 cubic feet sealed, you could try putting an aero port in, but you will be taking up a good bit of space with a 6" aero port and would probably end up with too little volume overall.
Matt
Matt
Ok thanks. So would you raise the cubes to compensate for the aero port?
Yes, when you are building a ported enclosure you aim for a certain airspace for the speaker(s), and then add the displacements from the driver, bracing, port volume, etc to come to a larger enclosure.
A 3 cubic foot ported enclosure would be larger than 3 cubic feet, closer to 4 cubic feet in reality based on outside dimensions.
Matt
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
KicktheSDbasshead
2 builds 2 feet
KicktheSDbasshead
San Diego
mat3833
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
