Please HELP ASAP Video Mod question
  • 1
ovsims
nc
I was wondering if you can run video to the nav screen in a Lincoln LS from a aftermarket source. I was thinking about how you had the patch the video line in the old Alpine CVA-1000 and was wondering if you could do something like that in the LS. Does anybody know what i'm talking about. Help please i need to know before i buy one of these.
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
ovsims
ovsims
nc
ovsims
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
