Questions about setting gain
  • 2
4BangerStanger
CarAudio.com Regular
117
5
DFW
So, I've been doing some research on how to set the gain on a sub amp. But, have a couple questions. What I've seen is that you play a 40hz track and turn the gain up until you hear the sound change. I'm curious if this process is the same regardless of power level and equipment? I'm going to be running a SoundQubed 1250 on two Sundown e8s. Also, the amp has a remote bass knob, so I'm curious how that factors into it. Do I just set the gain as stated above using the actual knob on the amp, and just use the remote knob to adjust the level as desired? The amp specs say that you can use the knob to adjust the gain from the driver's seat, but it doesn't override the actual gain knob on the amp, does it?
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
With 1/4 wave and tuning low, your vehicle is a resonator itself, like if you think about from your rear hatch or back of the box traveling front...
496
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
Thanks for the reply bass addict. I am sure with ya'lls help I'll get it tuned up. Audiobaun has been a huge help. He basically linked everything...
50
6K
I think he'sasking because electricity is often compared to water to make it easier to understand. It can be helpful, but it can be misleading...
8
4BangerStanger
4BangerStanger
DFW
danielbea122
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
