Rainbow Profi run by PG 600.2 cutting out
bruther
Hello all,
I'm currently running a set of 6 1/2's Rainbow Profi CS265 with the regular woofers. I am not running active. I'm powering the speakers with a Phoenix Gold 600.2 which has rated power of 150*2. I am using the amp crossover and the component crossover as well.
My problem is that the passenger side tweeter continues to cut out at high volumes. It is always the passenger side and never the drivers side. I'm not sure why this is. I do not run the speakers past distortion but I definitely play them loud.
Does anyone have any ideas of what may be wrong?
Is that a ti600.2? I ask because I run the CMX Kicks off of mine and I had a similar problem but it was with the whole right channel. I turned out the crossover pot on the amp needed cleaning as it wasnt making proper contact.
Also I dont recall if your set has the bulb in the crossover or not? But check it as well.
Thanks i will check......But if the bulb is lighting up in the crossover why wouldn't both sides be cutting out? Its only the passenger side tweeter. The woofer seems fine.
First off, seems to me you have the specs backwards. Ignore peak, stick to RMS. Neither of them is going to do great at 60hz, that is really...
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
I am out of the car audio world the more my ears age. However, I am very much still a hobbyist in the electrical field. With much of my current...
15
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
bruther
bruther
Washington DC
okiedokie
    Jun 1, 2024
    May 31, 2024
