Re Audio amp XTX 5000
  • 2
rlambert02
PHX, AZ
Does any one know anything about this amp or RE amps in general. I know they make good subs but I dont know about their amps. this amp is rated at rated @ 2500 rms.
So does anyone know anything about whether this is a good amp or not?
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
The 750 will give you better control at higher volumes as you won't be reaching clipping as soon..
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
rlambert02
rlambert02
PHX, AZ
needthat22
    May 31, 2024
    May 24, 2024
