Rear View Mirror problem
Eventually it will just fall off //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
my mirror would go into a orbit of directions everytime the bass hit in my maxima, i just got used to itafter a while and relyd on my side views and my blind spot...cause every other note the mirror would be all the way to one side......sickening....
mount a camera on your car and a tv inside to use as a rear view view mirror
Well that would be the expensive way. I would say when I deep note hits grab it with one hand and keep the other on the steering wheel. If someone looks at you funny then tell them that you are popping a zit!//content.invisioncic.com/y282845/emoticons/offtopic.gif.470a8b0541c72322a0037f48a8237473.gif
take the rear view off, a car is only illegal when all three mirrors are missing. If you have the two side mirrors, use them.
really not the point but how could you pop a zit if you have one hand on the wheel and other on the mirror?
Guys it's the little flip adjust that rattles. Get some molding clay/putty and paint it to match. Wrap it up in there around the piece that rattles. That should solve the rattle issue.
I did mention earlier that you might damage the glass. This sort of thing is not uncommon.
14
Thank you so much. I'll definitely give the wiring a go and see if that fixes it, if not then I'll try a new backup camera. Hopefully the head...
Ill also add that, its nice to have rear fill for passengers and for that surround sound affect, especially for an SUV or a 4 dr vehicle. If the...
38
863
Bumpin4ohms
Bumpin4ohms
Aurora, Colorado
bigbangtheory
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
