Remote Wire Troubleshooting
sizzl3r
Minnesota
sup /wiring
Since I'm upgrading systems, I was in the process of doing some rewiring for my truck. I got everything wired last week so I had my power wire just chilling in the back, and it some how touched the remote wire and sparked a bit. I know that's bad, but I didn't think much of it. When I got everything wired to the amp and turned the deck on, amp didn't turn on.
I figured it wasn't my ground because if it was, the amp would still turn on but go into protect mode. We brought out the multi meter and the power wire just fine. Checked for conductivity in the blue remote wire, and the wire itself was fine.
This leads me to believe the remote wire from my deck is completely fried. What the heck can I do to make this sucker work again? I'm so close to installing a new system and of course I run into an obstacle like this. Do i have to get a new deck? Are there ways around this?
Thanks so much guys.
Try tapping your remote signal from a separate 12v wire? Should be tons of accessory wire to tap off, just need to narrow it down on where to look.
Ya look for an ignition wire else where..tap into it and see if the problem is still there...but if your remote wire reads 12v now then its not the remote wire...
Conductivity check or continuity check btw? If it's the beep test, that's continuity. Won't tell you if you have power coming out of the wire.
^^^That. Just don't leave it that way or you'll come to your car and battery no worky worky.
I'm logging off for the night though. Hope you figure it out.
Tried tapping into the ignition wire(s), had no luck. Definitely should have worked. So I checked my fuse box....I HAVE MISSING FUSES. Pretty sure once I replace the missing fuses (like wtf) the ignition wire should work, and hopefully that should get it working. Hopefully. Gonna do that another day when its light. Thanks for the respnses.
yeah, it'll be hot but off. Just like your tv when it's plugged in.
Remote turn on. Going to check it later this week. Almost 100% certain it's something with the amp. I am assuming that a resistor inside went bad...
With the amplifier fused it will be fine for testing an amplifier to see if there is an issue with the remote wiring coming from the HU, or great...
As stated..A jumper wire from remote to Power on amplifier will be a nice little test to see if the amplifier is working. If it does, I would...
sizzl3r
sizzl3r
Minnesota
sizzl3r
maylar
    Jun 2, 2024
    Jun 1, 2024
