running amp from cigarette lighter
i dont consider subwoofer, amplifiers, etc. to be modifications... unless you remove factory panelling and replace it with custom panels. modifications are changing a vehicle's appearance, performance etc. such as body kits, twin turbos, all that ****. subwoofers are not modifications... to an extent. they can be placed in a car and removed at anytime
des343, weren't you the one that started a thread about JL/Sundown being overpriced pieces of crap a couple weeks ago. Then you started a keyboard commando fight with someone about amplifiers and how your thoughts were to get the cheapest amp possible with the biggest wattage because they are all the same guts anyways? If that was you, that was real helpful too bud.
1 if you would have READ it which CLEARLY you didnt i admitted they are great products juist overpriced which was what the ENTIRE thread was about....
2. it was in the thunderdome.
Ah yes........This post reminds me of my high schools days when I ran a small boombox off the interior dome light. The boombox ended up catching a small fire which left a smell that never came out.
Lmao @ this. I like you.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
515
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
Thanks for the feedback. It was a long shot but there will definitely be much more powerful subs in the trunk, so clearing it out isn't an option...
4
soundstream16
soundstream16
Huntington Woods, MI
tryan77
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
