Schumacher Electric auto battery charger
  • 5
Kryptonitewhite
Finally listened to you all and got a cheap charger at Walmart, 6A charge maintainer, microprocessor controlled, 72W 6amp fast charge 4A medium and 2amp slow 6V/12V automatic.
Hooked it up and let it sit over night. In the AM the remote unlock didnt work so I knew it wasnt charged. Looked at the charger and it said full charge. I unplugged it and tried to start it, dead. Reconnected, put back to fast charge, it started...the fan revved higher and higher then shut off. I unplugged and reset, put on slow charge, fan stayed low reve so I left it for 2 hours. Came back, said full charge, but was dead.
Gonna take the cheapie back today
ive ran the 15a version for over a year, never had an issue out of it. and the 6a has been used for a very long time by quite a few people that i know with no problem
sounds like its something wrong with your ride not the charger.
You could have a bad relay also..One of my Hondas did,and acted as yours.Something to check out also,sometimes you can tap on it with the key in on position.It turned rt over everytime I tapped on it just under the dash in the fuse panel..little black box/Relay.Worth a try?//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
pulled all three batts and brought them in, charger is on the starter batt, it kicks in for a few mins, then off for a few, I'll keep checking with the DMM...hope I'm getting somewhere!
so theres a little trick to getting completyely discharged AGMs to start taking a charge. The charger has 2 ways of shutting off, sometimes as soon as it starts charging the cooling fan gets louder and louder till it clicks and stops charging for a bit..then it kicks back in for a while and shuts off again, other times it thinks/says the battery has a full charge then you have to disconnect then reconnect until it kicks off again, process repeat. Once the battery gets a small charge then the process stops or becomes much less frequent and then it takes over a day to get over a 12V charge. So far I brought 1 battery back to life, the 2nd large 100aH is now starting to take charge...hasn't kicked off for a while. Tomorrow I will try to get the little starter battery going again.
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
611
you did. https://www.caraudio.com/threads/double-din-cd-player-with-screen-mirroring-a-link-android-auto-budget.614240/#post-8864499 OP:
AGAIN sonic does the same install stuff for free as well! Get a head unit with 4v preouts and 6 rca preouts as well they will be setup as front...
19
Kryptonitewhite
Kryptonitewhite
soo foo sd
Kryptonitewhite
    Jun 1, 2024
    May 31, 2024
