SEALED vs PORTED (basic info.)
or
product_thumb.php
with 2-p210"d4 on 500-1bd
From what I've read the Type R's like ported. I had 2 in a ported box tuned around 30hz and sounded very good in the lows. When it came to the hard hits they would distort and not handle very well.
Right now I have each of them in a 1sqft box with some fill. Still need to hook them up and see how they sound. I do like getting the very low tones and hope they will still be able to do them ok.
I have a 1992 Oldsmobile 88 and I plan to put a JL 10wx(250w rms) in the trunk. The JL site says I can either put it in a sealed or ported box. What would be recommended? I plan to pair the sub up with a JL 250.1 amp.
I listen to all kinds of music too. I just wanted a little more bass for my daily driver. Thanks for all the help guys!
I have a 1992 Oldsmobile 88 and I plan to put a JL 10wx(250w rms) in the trunk. The JL site says I can either put it in a sealed or ported box. What would be recommended? I plan to pair the sub up with a JL 250.1 amp. I listen to all kinds of music too. I just wanted a little more bass for my daily driver. Thanks for all the help guys!
It's pretty bad that you can manage to find the correct thread but still not bother to read it. Read the first post in this thread, it gives you the basic idea of what each setup will produce, then make your choice. It's personal preference based on what your goals are.
I do have a question...I'm looking at a dual 12" vented enclosure tuned at 34Hz. it has one 6" vent port on one side and no divider and it is built very stout double baffle and all. Does it matter that there is no divider (seperate chambers)? Also can someone tell me does it matter if inside of the enclosure that the corners aren't rounded (curved)? i heard that the bass is smoother if the corners and the port is curved.....The enclosure is 5 cubic ft......Thanks for your help in advance!!
The 45s in the corners are more geared toward high power, high SPL setups where anything that can be done to eliminate turbulence might increase SPL. Not to an audible degree, but 0.1dB can be the difference between 1st and 1st place loser. In you case, won't make a bit of difference.
I scrolled thru there trying to find TS specs and must have missed them or they weren't displaying. Anyway, looks like 2cuft tuned to ~35hz was a...
For what it’s worth… I picked up a mti stage 4 or 5 for around 900.00. Loaded with jl tw3 it’s was 1995.00. Which is a good 1k off what I would...
Assuming the taget curve is the same they will sound very similar. 2nd and 3rd order harmonics might be different but are offer hard to even hear...
😂😂 I actually have a CNC at my shop (I make drone parts for a living). It’s just that I got intimidated by all the tuning (equipment I don’t...
18
I dont think this forum is letting that link work. It keeps changing it to a link to this forum. Try this. Just change the dot...
10
BASS OUTLAW
Single sub fan
BASS OUTLAW
next street
Louisiana_CRX
    May 16, 2024
    May 16, 2024
