Server Issues
  • 7
Don't think the update helped with the spam issue.
I just clicked on six separate threads and they went well. Seems to have worked.👍
989
I think I know what could have been causing it and disabled the issue until a fix comes out.
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
476
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
administrator
Administrator
Little man on campus
administrator
33 Thomas St.
ThxOne
    May 20, 2024
    May 20, 2024
