Should i down grade
  • 4
BayAreaSlaps408
So I found out with my SQ Q1-2200.1 i might need to upgrade my stock 120amp alternator. Was thinking of down grading to sumthing around 1500rms so I don't need to swap out my alt and spend more $ !!! I know with A=W/V I would be around 125-150 amps depending on voltage from 12v-14v. Wit dat being said do think I'd be safe w my stock 120amp alt, solid battery and 1/0 gauge big 3 to push 1500rms??? Or if I have to just buy a 200 amp HO alt and keep my SQ2200.1???
And I know dis ain't all up to par w car accessories, amplifier efficiency,etc,etc,etc..... Just a quick mock up to get n idea of my situation
Any help, opinions or info will be greatly appreciated, THANKS!!!
Well what kind of vehicle?? The 2200 is pretty efficient but with 120 amp alt it's pretty marginal you would prolly b ok if you add a couple of batts but if you add a mid/high amp your gonna be drawing too much for that 120a alt to keep up. Reason I asked what vehicle is many times you can buy a stock replacement alt with a higher amp rating from a parts store like autozone for cheap. I have a rodeo that came with a 120a alt but autozone offered a lifetime warranty 180a alt for like 100$ ...you might get lucky and find a similar deal.
So your stock alt would prolly run the 2200 but its not gonna run much more than that. So a couple of batts and a 180 amp alt is your best bet.
Also I have a crap ton of alts laying around for Gm and ford so I might b able to hook an audio hommie up if you let me know what vehicle you have if its a Gm I have several 180 and 200 amp alts ill make you a good deal on.
The CT's are nice, That Sundown is a a frik'n beast!
854
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
713
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
830
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
BayAreaSlaps408
BayAreaSlaps408
San Jose, Ca
Bass4Days
    Jun 1, 2024
    May 31, 2024
