Skar SK-85.4
  • 2
06gtmike
Item(s) for Sale: SK-85.4AB
SK Series 4-Channel Class AB Car Amplifier
RMS power Rating:
4 ohms: 85 watts x 4 chan.
2 ohms: 125 watts x 4 chan.
Bridged, 4 ohms: 250 watts x 2 chan.
Pulse Width Modulated MOSFET power supply
Wired remote bass level control included
LED power (green) and protect (red) indicators
Variable bass Boost (0 to +18 dB bass boost at 45 Hz)
Soft start turn-on
4/3/2 or Mono channel operation
Speaker-level (high-level) inputs with signal sensing for automatic turn-on
Preamp rca outputs to daisy chain multiple amps
3-way protection circuitry (thermal, overload, and speaker short protection)
Heavy duty aluminum alloy
Input sensitivity:
Level: 200mV-6V
Variable high-pass filter (50-5000 Hz, 12 dB/octave)
Variable low-pass filter (50-5000 Hz, 12 dB/octave)
Item(s) Description/Condition: Works great, does have a few scratches across the heatsink as you can see in the pics. Comes in the original box.
Price: $160 shipped to the continental US. No trades at the moment. I also have a matching Skar Sk1500 listed, will sell the pair for $425 shipped.
Shipping and Miscellaneous Item Information: Included
570
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
928
Just make sure you don't buy a cheap eBay alternator. They advertise a higher max output but almost always put out less amperage at idle than your...
27
06gtmike
06gtmike
Williamsburg, VA
06gtmike
    May 12, 2024
Brendon Jenness
    May 11, 2024
