SoCal Skar Audio build
ok here is the second pod wrapped up:
and resin on both still setting
Got the boring tedious work out of the way
Testinf fitment. Its snug with the rockford!
Crossover under passenger seat. Perfect for it!
Random image before wire up and clean up
Cleaned up wires
it was pretty tough fitting that rockford lol. i was pretty sure it was not going to fit without building a false floor again which i did not want to do. but i got it
No more AP? and which RD amp is that? I've always fancied em. Are they just mounted to painted MDF?
nah. RD 1750v1 about 1800rms @ 1ohm of clean power! nice and efficient also. will play on low voltage too. not that i intend to do this lol. ALSO they are mounted to birch. trying to keep the weight down as much as possible. those birch pieces are bolted down throught he floor using some all thread and bolts countersunk into the wood.
604
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
937
Just make sure you don't buy a cheap eBay alternator. They advertise a higher max output but almost always put out less amperage at idle than your...
27
DonH
DonH
So Cal
TheUnderFighter
    May 12, 2024
Brendon Jenness
    May 11, 2024
