Sound deadening
Talk to the man with the green name via private messaging. B-stock is stuff that has minor cosmetic defects that doesn't get sold as A-stock.
whats B stock? where do you find that stuff
Audio Technix Sound Deadener - Better than Dynamat - B-Stock
its their "sub-perfect" product, still **** good to me.. i didnt notic anything wrong, they say it may have adhesion problems. i had problems.. with it sticking EVERYWHERE i accidentally touched it too.. lol its great stuff
lol it is really nice.
You know he bought Atmos Audio right?
Subs are on their way.
How could you not consider this ****? This is a 12 =P
i cant see the picture:furious: is it beefy?//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
My b-stock had a little adhesive leak and that was all. I would highly recommend you also buy a dampener roller and also look up some tutorials. My trunk is so **** heavy from the Audio Technix it will only pop from my key popper and not the one in the car. Also look up some expanding foam tutorials if you want to stop flex.
How much damper did you apply to the trunk lid? You aren't supposed to use the stuff to add mass.
Needed to add mass because my hinges could not handle the flex. Used 2 layers of 60mil and 1 1/2 cans of foam.
How much would I need to do just my trunk in a 1999 Saturn sc-1? I also have a buddy with a 1997 caddy sts thats going to want to do his trunk for sure and probably more. How many square feet is typical?
1 roll should be more than enough to do your trunk.
Ok, question.
for a 1971 Mustang, how many rolls would I need of this stuff?? Wanna take care of it all: top, bottom, sides, and trunk I guess....
I would start with 2 rolls and go from there.
I disagree with most. That **** is very sticky and only needs a quick wipe with isopropyl, assuming you aren't trying to adhere it to carpet or a...
33
I’m very far from a car audio expert; one only has to see my recent posts around here to know that. I am, however, pretty knowledgeable on cars...
22
1) That is correct. I bought mine from Amazon. Those were the actual links I used to purchase it. If you're budget conscious I'm sure you could...
Just got off the phone with Matt, that box isnt going to work, but ill put this out there..... https://www.soundoffaudio.com/ Anyone in south...
23
rdlyn13000
rdlyn13000
White Bear Lake
Falcons
    Jun 1, 2024
    May 31, 2024
