starting problems??
RangerDangerV2
st cloud MN
when I turn the key in my truck all of the accessories power up and the batt gauge says that the batts are charged. I also checked them with a boost pack and it said that the batts were charged... but when I try to start my truck it just clicks, doesnt turnover, just a click... I replaced the old ground to body with a new wire and that didnt fix it... so whats the problem??
Same thing happened to my car last week. My issue was a bad starter. There is a way to bypass the ignition switch on most cars by shorting something in the engine bay, but it varies from vehicle to vehicle. You could also remove the starter and take it to a NAPA, and they should be able to test it for you.
just hit it with the hammer like I said literally. If it starts up after that, your starter is going bad. If it does not start, take it off and get it tested at autozone and they can tell you for sure.
That happened to my chevy before...starter..it was actually stuck in the engaged position,nothing a hammer and big chisel couldnt handle
That's subjective. Personally, I find the hot/shrill sound produced by the comb filtering to be unbearable, so I wouldn't even listen to the...
20
ok so i realized the one u gave in the example did the same video stuff so i see the one mentions 13 band equalizer but the other has "higher"...
17
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
771
I suspect it's an ignition problem rather than a transmission problem. Start with the basics: plugs, wires, coils, check engine codes. Does the...
819
RangerDangerV2
RangerDangerV2
st cloud MN
audiobaun
    May 18, 2024
    May 18, 2024
