sub recone glue
  • 2
I haven't used it but I've used a ton of weatherstrip adhesive.
Makes sense though, it's a metal to plastic gluing application. That said, there are different chemical properties for glues that are made for polypropylene or PVC, for instance. They'll smell the same but that doesn't mean their chemical properties are the same.
thats kind of the theory im going off of. metal to plastic... although this is a foam surround im dealing with currently. any opinion on that?
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
439
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
462
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
568
Don't forget Hoffman's Iron Law. You can have 2 of the 3: low end, efficiency/sensitivity or small enclosure size...
4
698
chrisw91
chrisw91
phoenix, az
chrisw91
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
