Sub works fine, no voltage reading from speaker outputs to set the gain
  • 2
if you have sub play from amp when sub connected to amp sub/speaker output terminals then your doing it wrong when probing with meter.
I bet your set to ohms huh?
Ha no thank goodness I got the DMM set to AC Voltage but youre right..well initially I was leaving the wires in, but last time, I removed them, stuck the terminals in and screwed the thing down from up top and voila!! No Freakin Reading still!!? AMp works fine, everytihn does, Im just trying to set it up! grrr
If I recall, there ae quire a few made just for the tesla Y, all the tesla s for that matter...
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
71
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
513
Bellmeister
CarAudio.com Recruit
Bellmeister
Dallas
Bellmeister
Doxquzme
    Apr 28, 2024
Doxquzme
    Apr 28, 2024
Latest topics
