Sub works fine, no voltage reading from speaker outputs to set the gain
  • 2
if you have sub play from amp when sub connected to amp sub/speaker output terminals then your doing it wrong when probing with meter.
I bet your set to ohms huh?
Ha no thank goodness I got the DMM set to AC Voltage but youre right..well initially I was leaving the wires in, but last time, I removed them, stuck the terminals in and screwed the thing down from up top and voila!! No Freakin Reading still!!? AMp works fine, everytihn does, Im just trying to set it up! grrr
Well.. Not sure you could wait that long.. But the 4th is coming? might be the time snag them up then? i wouldnt think they would perform too bad...
127
333
416
I have a Y as well, so many options you can go with. I'm running 500 watts to a JL 10W6v2 and its more than enough output for me (1.25 @ 32hz)...
645
490
Bellmeister
CarAudio.com Recruit
Bellmeister
Dallas
Bellmeister
    May 12, 2024
Brendon Jenness
    May 11, 2024
