Subs glued to box
You might try a heat gun and pry gently.Take your timewith a flat pry bar and hammer. Must have had a seal leakage and didnt want to remove the subs and make a new baffle which is cheap to do
Yeah. I vote heating and fishing line. Great suggestions. That's how we take cap block off retaining walls that have been adhered together. Should have thought of that in first place.
I'm going to try that sometimes this week. The guy I got them from had them all wired weird and I had to go in and wire them to 1 ohm but had to use the port to stick my hand in there. Long story short it took over an hour and I had to cut another hole then glue it back on the box
Sent from my SM-N920T using Tapatalk
Hammer a flat head screw driver under the basket in a few spots and pop those woofer right out the box. Easy as that. Done it a few time on painted enclosures where the woofers are stuck to the paint like glue.
Kodas like big sealed boxes and can't handle power. I shredded the surround on my 8 in .4ft³ and 350w My 10s on 1000w for the pair one coil...
9
288
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
441
Well, get Two then and try to share for peeks sake!! :poop: :ROFLMAO::ROFLMAO::ROFLMAO:
16
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
513
Chalo_209
Chalo_209
Kingsport tn
Based
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
