System Skipping
  • 2
audiofool
I own and self-installed a Jensen audio system in my truck several months ago, and I've been having problems with it either skipping on or not even playing tracks 5 - 7 of every cd I play. When it does this, sometimes it just tottally locks up and I can't change tracks untill it decides to play. Is there something I can do to fixit or is it just something to send back to jensen or trash ?
well, I will be nice abouth this, jensen is not a verygood brand, and this sounds typical of their units. Warranty (if that is still good) is what I would suggest. If you decide to trash it though, I would recommend a pioneer cd player. In my experience they have been the best for the buck. I personally have never owned one, but when you are in the business for a while you see just about everything. You could get one for about 169.00 in some cases/sales
It sounds like there is an internal problem with the laser lens being off alignment. Nothing that you can do but bring it in for repair, which will probobly cost more than the deck is worth. The reason that it is locking up is because the laser cannot find the signal when the laser lens advances towards that area of any CD.
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
291
658
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
16
audiofool
audiofool
Louisville, Ky
