t3 t 1000 12
  • 1
psychoacoustics
hammer and the evil one
3,468
Buffalo NY
t3 audio
t 1000 12"
Power handling: 1,000 watts RMS/2,000 watts peak *VCdia: 2.5" *Le: 1.37 mH *Impedance: 4 ohms *Re: 4.36 ohms (x 2) *Frequency response: 30-1,000 Hz *Fs: 34 Hz *SPL: 89.51 dB 1W/1m *Vas: 0.92 cu. ft. *Qms: 6.63 *Qes: 0.70 *Qts: 0.63 *Xmax: 20.5 mm *Dimensions: Outside diameter: 12.76", Cutout diameter: 11.10", Depth: 7.10".
150 shipped
free shipping
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
I just bought the stinger 1500. I watched a video on YouTube that there is an issue turning the gain all the way down using the amp, and you have...
  • Locked
Do you have any pics with user name and date or is this at a local garage sale?????????????????
The JD does ~800 watts@ 3 Ohms so I assume there would be no noticeable difference.
752
psychoacoustics
psychoacoustics
Buffalo NY
psychoacoustics
Doxquzme
    Apr 28, 2024
Doxquzme
    Apr 28, 2024
Latest topics
