The basic 3 and HO Alternator
Ya you probably don't need a H/O alt for only 1200w, what size is the stock alt?
Big 3 use 1/0, no point in using smaller cables when it's so cheap as it is, make sure to fuse it / etc
I think those car have 120s but I'm not sure
If thats the case that should be plenty for 1200rms
Start with big 3, if you still have a voltage drop, get 2nd battery, should be good after that, can get deka's from bad4health for ~120 i think, could be closer to 140
I used Cadence 0gauge for my Big3 you can get 7.5feet which should be all you need off evilbay for like 15$ shipped, decent quality wire too. I have a 2.2L Ecotech in my 04 Cavalier which I think is maybe the same engine as the Cobalt? Just guessing. If thats the case you'll have at least a 105 amp alternator. I'm running more than twice the power you have right now off all stock, I have dimming issues and I'm probally starving the amps a little bit, but I am not experiencing any major issues. New Battery on the way and I'll get a HO alt later, but I'd say for what you're running you should be just fine with no dimming even off stock with a Big3 upgrade to your wiring like these guys are saying. Oh also you might have to go from under the car to get to the + charge bolt on the alternator (it was a huge pain for me) but the - runs were simple.
So, assuming that you aren't using an LOC and are using the hi-level (speaker) inputs, use the speaker leads off of any of the R/L speakers (front...
39
4K
I can't speak to carplay but I'm using a Joying unit for android auto. It's a single din slot with a screen that attaches. The single din units...
https://www.amazon.com/dp/B01EXOTD56/?tag=caraudiocom-20 Cant go wrong with these for the price and drop ins on HU power alone. They do much...
grocery getter
grocery getter
Yorkville, IL
grocery getter
    May 18, 2024
    May 18, 2024
