The basic 3 and HO Alternator
Ya you probably don't need a H/O alt for only 1200w, what size is the stock alt?
Big 3 use 1/0, no point in using smaller cables when it's so cheap as it is, make sure to fuse it / etc
I think those car have 120s but I'm not sure
If thats the case that should be plenty for 1200rms
Start with big 3, if you still have a voltage drop, get 2nd battery, should be good after that, can get deka's from bad4health for ~120 i think, could be closer to 140
I used Cadence 0gauge for my Big3 you can get 7.5feet which should be all you need off evilbay for like 15$ shipped, decent quality wire too. I have a 2.2L Ecotech in my 04 Cavalier which I think is maybe the same engine as the Cobalt? Just guessing. If thats the case you'll have at least a 105 amp alternator. I'm running more than twice the power you have right now off all stock, I have dimming issues and I'm probally starving the amps a little bit, but I am not experiencing any major issues. New Battery on the way and I'll get a HO alt later, but I'd say for what you're running you should be just fine with no dimming even off stock with a Big3 upgrade to your wiring like these guys are saying. Oh also you might have to go from under the car to get to the + charge bolt on the alternator (it was a huge pain for me) but the - runs were simple.
Without the wiring diagram I cannot be certain of the color associated with the head unit remote on or even if there is one on the HU. I assume...
47
5K
I can't speak to carplay but I'm using a Joying unit for android auto. It's a single din slot with a screen that attaches. The single din units...
https://www.amazon.com/dp/B01EXOTD56/?tag=caraudiocom-20 Cant go wrong with these for the price and drop ins on HU power alone. They do much...
Hello I also have a question I want to buy 160ah lto, i.e. 4 banks but I have a stock alternator of 140 a and a maximum load of 14.9 do you think...
grocery getter
grocery getter
Yorkville, IL
grocery getter
    Jun 1, 2024
    May 31, 2024
