truck sub box, how to secure box?
  • 5
$$$1smiley5$$$
high climber
18
toronto
hey guys thanks for all you help allready. I got my system hooked up and installed but now it seems the box is movin around a bit and vibrating off the back of the cab, could I screw into the box from the outside with rubber washer screws ? I have looked at dynamat and it is EXPENSIVE is there anythoing else i could use? I am not lookin to enter any competitions so....
any help would be much appreciated
I did see what type truck you had
If it’s a regular cab just take a sub out and screw the box to the back wall
o.k I thinbk I will take the sub out and screw it to the back of the cab but should i put something between the box and the cab? like dynamat or something or wil screwing it stop any unwanted vibration? is there anything else CHEAPER than dynamat I can use do dead the sound outside the cab?
i would dynamat anything you can, especially if you have a small truck system. dynamat the back wall, side walls, floor and doors. you can do the head board also. dynamating 1/2 my truck made a difference, and it's louder to the ear. i still have to do doors and head board.
front doors are subs...fyi Go with AudioControl 6x9 components up front and coaxials in the rear. You will be impressed with just changing to that.
4
576
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
Then I would get the dual 4 ohm subwoofers and wire it to 1 ohm like in the link below. Those subwoofers are 500 watts rms so running them at 1...
8
ok i get it dodge ram and full strip inside for second skin . power is run down drivers side and speaker wire is run down passanger side thank you
$$$1smiley5$$$
high climber
$$$1smiley5$$$
toronto
$$$1smiley5$$$
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
