Tweeters to compliment 608GTI MKII components?
  • 2
PrinceCharming
PrinceCharming
I am getting a pair of JBL C608GTI MKII components to go in my Grand Am and I am going to drill holes and point the tweets toward the windshield so I will still have my stock mounting place open and a Kicker IX402 just sitting around so I figured I would get a couple soft dome tweets to compliment the JBL titanium tweets. The stock mounting place is on-axis, 1-inch/25mm.
My question is what tweeters would work well with this set up? I would really like to have some soft domes to go with it if they will work. I dont know how to tell which ones would work because I can't really listen to any. What would you guys recommend?
Kicker Impulse IX402:
stereo, bridged mono, or Tri-way output
frequency response 20-20,000 Hz
40 watts x 2 at 4 ohms
120 watts x 1 in bridged mode
60 watts x 2 at 2 ohms
speaker-level inputs
MOSFET power supply
0-18 dB bass boost centered at 40 Hz
0-12 dB treble boost centered at 18,000 Hz
18 dB/octave crossover switchable at 70 or 110 Hz
If you guys need any more info just tell me. Thanks.
I did an adire koda 8 for now but I'm considering swapping it to a Dayton ho 10. More cone area for more midbass. But I might not need to. I might...
16
You can Email or Call GP Audio and they can make some adjustments to make the enclosure shorter and either deeper or longer on the Glue and screw...
114
9K
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
PrinceCharming
PrinceCharming
PrinceCharming
New Albany, MS
trumpet
audiobaun
    May 19, 2024
    May 19, 2024
