what amp 4 hx2's
  • Thread starter <john>
  • Start date
  • Replies 5
  • Views 2K
you can get a sony 3001sxd for around $200. it is rated at 1000 watts at 1 ohm. since the subs are dvc, you can wire the coils on each sub in parallel and then wire the two subs together in parallel for a 1 ohm load.
First off dont listen to Kithut84, do not lower the ohms to 1 ohm to each sub, u might blow ur sub doing that. The RF power 800 is a good amp, and the RF bd1000 is good. whatever you do, do not wire everything to drop the ohms to 1 ohm.
shocker, why would that blow the subs? they are rated at 500 watts rms each (1000 total if you can add) and the amp is rated at 1000 watts at 1 one ohm. 1000 watts going to subs that can handle that power would not blow them unless you have the gain too high. dumbass
Originally posted by Shocker28:First off dont listen to Kithut84, do not lower the ohms to 1 ohm to each sub, u might blow ur sub doing that. The RF power 800 is a good amp, and the RF bd1000 is good. whatever you do, do not wire everything to drop the ohms to 1 ohm.
How is lowering the impedence of the subs going to blow them ? If the sub can handle the power. I don't see the problem.
[ 12-28-2001: Message edited by: ramos ]
114
354
  • Locked
660
Amp
477
Guest
ramos
    Jun 1, 2024
    May 31, 2024
