What ya think? For an obsidian 15 D2 on an apsm 1300
I'd do the box exactly as designed. The 45s may not help with the overall SPL ect.. but it will provide some "bracing" and the box was designed with them, so I'd keep them in there.
okay.should i just glue and screw them in then seal all the gaps will caulk?
that should do //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Or just glue em if you have clamps to make them stay where they need to be til the glue dries.
I found a buddy to cut them for me. So one of my friends said there's a special way to put them in and its really difficult. Doesn't seem that hard? Cut 2 by 4 so its a 2 by w/e I need let's say 3 and a quarter. Cut it to 15 inches height. The just cut those sides at a 45* angle on both side. Apply glue and push into place then screw in after glue dries then apply caulk. Right? Not that hard? Or is the small space that will be behind the 2 by 4 between it and the wall bad? Should I fill that with caulk?
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
Do you still have this? Where are you located?
I agree with AnthonyO. I use a lot of audiocontrol products the dsp is easy to use and with the acr3 you have a few different options on bass knob...
Also if you did decide to get another amp the output rca on the amp can be adjusted with the internal dsp
Mr.meyhem
Mr.meyhem
Cold as F***, MN
Mr.meyhem
