Whining through speakers
  • 4
Usually it is, I've done both and have seen that sometimes when I get a whine through the speakers it is because of that ground not being right. Bolt it to someplace behind the dash and the whine goes away. Yet other installs I have had no whine so it all depends on the car and the quality of the grounds in it from factory.
Grounding to the car chassis instead of through the factory harness didn't make a difference so I ran a bare wire from the screw near the rcas and touched each rca shielding with the wire and the noise went away.
I'm getting a whining noise from my one speaker anytime something in the truck activates. When lights are triggered to turn on. Happens when the...
Hello there people! Ive recently purchased a car and it came with a sony xav ax headset. It could be an ax3000 or ax3200. Im wanting to upgrade...
Some manufactures actually cut out some of the low end to prevent speaker damage to the factory speakers. I would consider trying one of these for...
Good luck. Front facing USB it's rare and it's not hard to reroute a USB from the rear. 300 isn't enough for any quality touch screen with 3 sets...
10
2RZ-FE
2RZ-FE
Dixon, Ca
2RZ-FE
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
