will this new upgrade be worth it!! please help!!!
well realisticly the amp pushes maybe 550 real watts...someone also told me the sax 125.2 is for mids, not subs...so the question is...would i be better off with the Mmats 600.1 or two sundown sax 125.2
Power is power, but one thing, well two things to keep in mind about D class mono vs. multi-channel. Mono are usually made for subs, so they have better control options (x-over+boost as opposed to x-over only) and you don't end up with either ridiculously high ohm loading, or craptastic wattage bridged like you do multis
yea but will it be better to go the sundown route and have the two amps....or the mmats with one powerful amp....im lookin at the sundown but idk
well when i say im not rich...i mean i dont wanna spend 200 more for the mmats....which is why for 200 id get the sundown and add it to the existing one...have the same amount of power for 200 bucks cheaper...i still dont no what i wanna do tho
your question has been answered multiple times, you just dont like the answer
in the end you have to make the decision, but this thread is done
dude, just save for a few extra month and get the better amp. Why are you gonna come on to the forum, ask for people's advice, and then when they give it to you, tell them how it isn't what you want to hear.
And about not being rich, you're buying DD subs, and a SD amps, how are you gonna say you're not rich when you're buying some of the most expensive equipment on the market?
eeeh well maybe i should of named the thread differently....there is going to be NO MIDS for gods sake. i want somthing to power subs. no speakers, im using factory. so, what the bulk of the thread is, i want to no what you prefer, the two sundowns, or the one Mmats. id sell the existing sundown to get the mmats, im not keeping it. so two sundown sax 125.2 Vs one Mmats 600.1. maybe that will clear it up for you guys. again, this is to power SUBS
If you like the sub you have, then continue to run it. I would look at what improvements that could be made to do some deadening and maybe port...
Hello, I have a Peugeot 207 SE 2007 and would like to upgrade its existing car stereo. It’s a single cd fm/am radio and I would like to get...
That's not an amplifier designed for subwoofer use, it's a 4 channel designed for you primary speakers. Small $75 investment to get you where you...
598
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
727
Thought I would update this thread… Couldn’t login over the weekend for some reason. Finally got the Kenwood installed last Friday… Had a little...
32
Gatman
Gatman
Milbank, SD
Ineed$
HandsomeSteve
HandsomeSteve
