wiring with 2 amps??
Okay so I'm not really sure the best way to wire this system....
I have 2 dvc 4 ohm sound stream 15" subwoofers 1000watts rms and I have 2 hifonics 1200 watt monoblock amps stable and 1, 2, & 4 ohm
Now I was wondering if there is any way to get 1200 watts to each subwoofer? And if not is it better to wire both subs to 1 amp at 1 ohm or wire up each sub with its own amp at 2 ohm?
strap em and run it at 4 ohms bridged, you should have some more head room.
or you could have fun with your amps on 1 ohm bridged. (not recommended)
I have only one amp hooked up right now bridged at 1 ohm? How can I make both of them bridged at 1 if I only have 2 dvc 4 ohms?? And is it better off running two amps? I was just wondering how to get the most power too my woofers
you can't bridge 2 amplifiers together.
you can wire each sub itself 2 ohm, then connect each one with it's amplifier.
but it's better to run one amp rather than 2 amps, also it's better to wire the 2 subs together rather than wiring each one itself
you want to wire the two subs together either 1 ohm or 4 ohm depending on your amplifier specification
i recommend to sell your 2 amplifiers and get a new one (1 ohm stable with at least 2500 rms rated @ 1 ohm)
Just ignore Red...he's wealth of useless to dangerous advice...all without knowing what he's talking about
19
3K
You can try that Seat Bolt for a ground location. Remove all paint down to Metal. Place a Washer then One amps ground Ring terminal(copper..sand...
7
Deff need to lnow what subs.. Make and Model# would help quite a bit. What amplifier will you be using?
97
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
361
ima hotdogstand
ima hotdogstand
Allendale, MI
Yaris
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
