wiring with 2 amps??
Okay so I'm not really sure the best way to wire this system....
I have 2 dvc 4 ohm sound stream 15" subwoofers 1000watts rms and I have 2 hifonics 1200 watt monoblock amps stable and 1, 2, & 4 ohm
Now I was wondering if there is any way to get 1200 watts to each subwoofer? And if not is it better to wire both subs to 1 amp at 1 ohm or wire up each sub with its own amp at 2 ohm?
strap em and run it at 4 ohms bridged, you should have some more head room.
or you could have fun with your amps on 1 ohm bridged. (not recommended)
I have only one amp hooked up right now bridged at 1 ohm? How can I make both of them bridged at 1 if I only have 2 dvc 4 ohms?? And is it better off running two amps? I was just wondering how to get the most power too my woofers
you can't bridge 2 amplifiers together.
you can wire each sub itself 2 ohm, then connect each one with it's amplifier.
but it's better to run one amp rather than 2 amps, also it's better to wire the 2 subs together rather than wiring each one itself
you want to wire the two subs together either 1 ohm or 4 ohm depending on your amplifier specification
i recommend to sell your 2 amplifiers and get a new one (1 ohm stable with at least 2500 rms rated @ 1 ohm)
Just ignore Red...he's wealth of useless to dangerous advice...all without knowing what he's talking about
19
You can try that Seat Bolt for a ground location. Remove all paint down to Metal. Place a Washer then One amps ground Ring terminal(copper..sand...
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
415
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
488
ima hotdogstand
ima hotdogstand
Allendale, MI
Yaris
    Jun 1, 2024
    May 31, 2024
