wtb 15s or 12s and amp
Are they for sq or spl
TC9 motor. Generally pretty musical, but can get loud. Ask Spooney or Av83 how they like theirs.
If you're into straight SPL I can use a different coil which is lighter, usually gets more peaky, but doesn't hold as much long term power. The "normal" coil I'm using models nice for 15" 4 cube , or 2.25 cube for 12" tuned low 30's.
how will they compare to my old subs in my sig...also i only have about 7.8 cubes to work with
Have 3 bnib powerbass xs12 or pair bnib PBx xs15? These subs are better than the sa subs..Also audiopipe 3k?
Should be a little more musical, since I'm guessing IA uses a very stiff suspension and they probably have a bit more motor force which tends to get a peakier sub. Also I use Copper coil which lends itself a bit better to musical applications and has a slight edge on long term thermal power handling (don't expect miracles, but side by side Aluminum would fail a little before copper)
I don't know if IA publishes TS specs so hard to say for sure.
Thermal handling should be about the same.
DP's are MSRP 400$+, and I'd say the motor is more comparable to TC3hp. These are at your doorstep for
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
644
Man, I hope you find what you are searching for. It is deff worth the time spent for something you always want back or wanted period.LOL I was...
809
  • Locked
COMPLETED WTB Eclipse SC8365
I checked at Diyma and I signed up for an account but I cant post in the classifieds. Thanks for the tip, I'll keep a check there.
7
  • Locked
I can get this to somewhere in NJ in US. Is that possible for you to ship that out ?
12
3K
slvrado28z
slvrado28z
midland, tx
hispls
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
