Solution to rear view mirror tilting from hella bass
Tommyxm
Alright so If you cut a piece of cardboard to the same shape as the mounting bracket and u fit it into the rear view mirror after you've unscrewed it u can shove it back on to the metal plate and that will help eliminate the tilt.
I normally just take them down, I had one get ripped off the windshield once and it chipped it, causing me to have to replace the whole windshield.
i doubt this solution works, just take it off. youll find thru trial and error that you basically have to choose between big bass and a rearview when you have a car that has a vibration issue. My old i30t had a great rearview and never had an issue, but my accord is a different story
Set it and super glue the joints. If that doesnt work nothing will
even then its iffy as the windshield will flex like a mofo. Mine moved so much it ripped the rearview off completely and even took the inside layer of glass with it. Glue on the chunk of metal attached to the glass held up better than the glass itself after 50 bajillion back and forths
Pretty much this. I assume you've got an older car and the joint on the mirror is worn and loose. If you want to keep the mirror then set it where you want and epoxy that ***** in place. Cardboard will not help at all.
I throw mine out. As long as I have my outside mirrors on the vehicle, Its legal to travel down the road in this state.I cant hardly see out of them half the time at 3/4 tilt
i had a similar query quite some time ago and got the same replies. The only thing that can be done is to change the resonant frequency of the rearview itself. But even that will yield only minimal results. The cardboard idea is pretty well bunk, as all it would be doing is adding a suspension component, or even a less effective gasket component. Depending on the car, there really isnt much you can do to mitigate this especially if the rearview is directly connected to the windshield. sometimes if its connected to the ceiling, then you can do somewhat better if you stiffen the sheetmetal around it or just deaden the fuwk out of it
Oh man, that's like s3x with your mother in an elevator, wrong on every level!
27
38
841
I’ve tried it in 3 different vehicles and multiple locations. Rear deck is best for me. Unless it’s a midbass I don’t want anything in the rear...
974
Tommyxm
Tommyxm
youdoofus
    May 31, 2024
    May 24, 2024
