HELP! Wiring issues on Boss PV3700 amp and I'm too ignorant to figure it out
  • 2
Rowdyrod59
Installing a Boss PV3700 amp in my son's Durango. Ran all the wires like manual said, but the amp won't power up. Put my multimeter on the power and ground (key off - 0.00v), (key on - 0.00v); Ran a wire from battery ground to connect to my multimeter and rechecked (key off - 14.7v), (Key on - 14.7v). Checked the ground output from the amp to the car (neg multimeter cable connected to neg battery terminal, positive cable to amp ground - 14.7v with key on or off). Remote switch source (key off or on - 0.57v). I thought that maybe the problem so I made a jumper to supply 12v source. Still nothing. I don't know much about electrical and I don't know where to go from here. Any help is greatly appreciated.
555
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
943
994
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
Rowdyrod59
Rowdyrod59
Tucson, AZ
Rowdyrod59
    May 19, 2024
    May 19, 2024
