No sound from radio/CD. Parrot Bluetooth fitted
Winston551133
Uk
Hi I've just bought a 2008 Renault laguna that had a parrot ck3100 already fitted. I'm getting no sound from the radio/CD. Shows radio stations and CD playing but nothing from speakers. I do get sound when I make a call through the Bluetooth unit. Could the parrot be the issue? Or has the amp gone?
From what I read, the Parrot mutes the radio when a phone call is in session. It may have glitched and left the mute activated. Is there a way to disconnect power to it? According to the specs, it is hardwired.
I would try to remove power to the unit and it may reset back to standard setting after placing power back to it. Pull the fuse in the Fuse panel for Radio should work also if connected by existing harness?
If the bluetooth is integrated into the head unit, and no sound, my first thought is that you most likely blew an internal component. Possibly...
Water or moisture on any Electronics is never a good practice nor a great out come of operating correctly . If you want to keep that same unit, Id...
Just got off the phone with Matt, that box isnt going to work, but ill put this out there..... https://www.soundoffaudio.com/ Anyone in south...
23
887
19
894
Winston551133
Winston551133
Uk
    May 16, 2024
    May 16, 2024
