147 db on a LOW tuned box
my subs don't play over 45hz right now, and will probably be dropped down to 40hz after I get better mids. Doesn't mean there should be a drop in volume. The biggest problem with this whole argument is the fact decibels do not say how loud something is, I want no audible dip in output, I could care less what score it does.
But if your subs don't play over 45 hz, how is that not a drop in volume to 80?
And if you have a drop in volume over 60, you can have an increase in volume in other places //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
because like I said, db's do not dictate audible output. If you were to sit in a car doing 150db at 2khz you would go deaf instantly, it's much much louder then 150db at 35hz. you can be down 10-20db and have the same volume just depends on the freq
---------- Post added at 01:30 PM ---------- Previous post was at 01:29 PM ----------
and my system doesn't dip because I built it not to.
what ^ said. amp gain setting info, test tones are at the very bottom...
545
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
700
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
Some manufactures actually cut out some of the low end to prevent speaker damage to the factory speakers. I would consider trying one of these for...
Joe562MMA
Joe562MMA
Los Angeles , CA
wenn_du_weinst
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
