2003 Jeep Grand Cherokee
afearlesshunter
This will be probably be super slow but..
This is my second vehicle so far ( first one was totaled by my brother) and It will end up being walled once I get all of my stufffsss. Keep in mind this is a high school build and i make minimum wage, so bear with me. Not much but its getting there //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Current gear:
Kenwood KDC-X397
4 gauge CCA Knu power and ground
Alpine MRV-M500
2 Polk audio PSW 505 12's... (Temporary!)
4 cubic ft enclosure tuned to 32hz
On the way:
SSA Xcon 18 //content.invisioncic.com/y282845/emoticons/woot.gif.aaa6090e619a97b6090d16dd863c5a69.gif
Future:
1/0 welding cable
Crescendo s1500
Eventually a second xcon
Eventually a bigger alt
The Newish to me jeep
Power run
Head unit installed
Cheap *** Volt meter and amp remote
Tiny amp
Temporary subs
Oh no a high school speed build... ha just kidding man, sounds fun. Keep the pictures coming when you can
They are .. meh.. better sounding than walmart crap but i wouldn't pay for them. They do get pretty low thought, 27 hz flops sunroof and all doors. The big downfall is the efficiency is fairly low compared to other woofers in the same class.
dam those home audio subs look decent. I bet with some power they'd be decent. Looks good so far.
If I may throw you a tip:
Get that fuse as close to your battery as possible when you run your new wire. it's the only thing protecting your car from burning to the ground if some should ever happen. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Small update
Crescendo amp came in. Have subsonic set at 10z because anything above cuts out my 27 hz.. maybe I'm just down syndrome..
and bass knob was broken in the box....
Installed with my 4 gauge with 80 amp fuse. running 4 ohms till welding cable comes in.
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
Might not even be an issue if you don't have any really big panels on it. Otherwise dowels or threaded rod across your wide panels would be the...
18
Please. Quit talking shitt. I might be dumb but I'm not stupid.🤣
16
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
606
afearlesshunter
afearlesshunter
Greenfield, IN
afearlesshunter
    Jun 1, 2024
    May 31, 2024
