3" Mids CDT Audio MX-3F
  • 1
trumpet
Barry Schanz
//content.invisioncic.com/y282845/monthly_2019_02/1670838185_CDTAudioMX3F2of3.jpg.0d8a729c83d4885849c6c65e0b200a64.jpg
View Listing
MX-3F 3” cast mid-woofer
The devil is in the details and so is the magic.
The cone of MX-3F midrange drivers is made of a light, yet rigid, mixed fiber fiberglass. Producing unrivaled midrange that is engineered just for your car to make the most perfect blend with any CDT tweeter and crossover.  Small size midrange for the true audiophile listener.
MX-3F
Technical specs and contents
  • 1 pr 3” mid-woofer
  • Frequency response 90Hz-11.000Hz
  • Power handling: 100watt (150Watt Pk) HPF-250Hz
  • Impedance 4 Ohm
  • Sensitivity: 85.9dB
  • Mounting depth: 1.69” (43mm)
  • Cut out diameter: 2.90” (73.7mm)
  • Frame: OD 3.7” (94mm)
  • Cone:Mix fiber glass
  • Magnet weight 7.2 Oz
  • Cone surround rubber
  • Voice coil: 1.0” (26mm)
  • Fs: 110Hz
Ive ripped out my SPL build in my truck a few months back now and have a temp setup atm. I am planing another SPL set up and rebuilding and will...
10
Hell of a deal, I think it may be the last day. If you're considering going to a 3 way, here's a great buy! You have to load them into your cart...
I agree with DJ. Pro style speakers are designed for large ported enclosures and lack bottom end without an enclosure. Plus they tend to suffer...
I think you need like a 10x switch on an amp? You would need to bandpass the mids or something Pioneer network mode or similar? I know the new...
trumpet
Barry Schanz
trumpet
St Cloud, MN
trumpet
